PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Newfiedrool
Dec 17, 2020Virtuoso
Did you perform a reset afterwards? If not I would factory reset and set up as new.
Morse75
Dec 17, 2020Guide
Newfiedroolok, I will try the reset tonight, now my wife and myself are working from home (thanks to the Covid), so I can't break everything...
- NewfiedroolDec 17, 2020Virtuoso
Updated, factory reset and set up as new, pleased to say it's all running fine.
As this is a move from the old QCK SDK to the new SDK it's important to factory reset after this update.
Christian_R thanks for confirming yesterday this was the firmware.
- KiseraiDec 17, 2020Tutor
Newfiedrool wrote:Updated, factory reset and set up as new, pleased to say it's all running fine.
If this firmware requires a factory reset it shouldn't have been pushed as an auto update. With a lot of us working from home due to COVID, it was a real shock to wake up to no internet connection on devices I use for work and I ended up being 45 minutes late for the start of my shift yesterday. If it had been absolutely no connectivity at all I would have had more time to fix it, but because the wifi was working correctly I had no idea there was an issue until I went to use my wired-in work computer.
When I get a chance I'll try to reinstall and do a full factory reset, but I'm still very unhappy with how all of this went down and the lack of communcation around it.
It should have not been pushed, I agree. Not sure how it could have been communicated in such a way to instruct users to manually update and reset though.
best way is to turn off auto update and check on the support page once a week but many of us will perform a reset after any update. This helps to clear the NVram of old code and Merlin did a thread on Smallnetbuilders explaining why a reset is required.
Of course it's not mandatory but a reset is the preferred way to go.
- Morse75Dec 17, 2020Guide
Newfiedrool sorry I have forgot to thanks you for the advise :-)
Morse75 wrote:Newfiedrool sorry I have forgot to thanks you for the advise :-)
No probs, good to hear you are up and running again 👍
