PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Morse75
Dec 17, 2020Guide
Newfiedroolafter a reset, it works again, all the devices are connected again to the 2.4GHz wifi.
However I have lost the link wit the Netgear Armor: it is offering to activate a trial when I still have 6 months of subscription to go
what should I do? on the Netgear Armor support page, i have found anything related to that
dcinca
Dec 17, 2020Apprentice
Have you tested the the latency when connected to 2.4ghz?
- NewfiedroolDec 17, 2020Virtuoso
I'm not seeing an issue on 2.4Ghz
Ive run tests including ping plotter and it's fine, can't see an issue. It's not showing spikes my end.
- TopologyDec 17, 2020Virtuoso
Newfiedrool, I am curious: can you please elaborate on your prior comment, “…this {firmware 1.2.0.16} is a move from the old QCK SDK to the new SDK” (message #33)? What software development kits are you referencing?
Thank you.
FYI: I successfully updated the RAX120 firmware from 1.0.2.136 to 1.2.0.16 – and, it appears that everything is currently working as expected.
To install the update, I simply downloaded the ZIP archive containing the new firmware to my PC desktop, extracted the RAX120-V1.2.0.16.img file, and used the manual "ADVANCED | Administration | Firmware Update | Locate and select the upgrade file on your hard disk" process.
It's just an update that's all I can say. Im guessing the new packages now include a bunch of security fixes as maybe the old format was no longer supported.
It was a big update hence a reset was required for this which is solving the issues that were popping up on the thread.
