PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Topology
Dec 17, 2020Virtuoso
Newfiedrool, I am curious: can you please elaborate on your prior comment, “…this {firmware 1.2.0.16} is a move from the old QCK SDK to the new SDK” (message #33)? What software development kits are you referencing?
Thank you.
Topology
FYI: I successfully updated the RAX120 firmware from 1.0.2.136 to 1.2.0.16 – and, it appears that everything is currently working as expected.
To install the update, I simply downloaded the ZIP archive containing the new firmware to my PC desktop, extracted the RAX120-V1.2.0.16.img file, and used the manual "ADVANCED | Administration | Firmware Update | Locate and select the upgrade file on your hard disk" process.
