PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Crtfdgk
Dec 17, 2020Star
I still cannot get any internet access on devices connected via Ethernet after updating to 1.2.0.16 and performing a factory reset. I verified that after downgrading to 1.0.2.138, everything works fine, but I was automatically upgraded again last night and it re-broke my setup, and performing another factory reset still doesn't enable Ethernet connectivity. Has anyone had persisting Ethernet issues after a reset and an upgrade to 1.2.0.16?
Newfiedrool
Dec 17, 2020Virtuoso
Crtfdgk wrote:I still cannot get any internet access on devices connected via Ethernet after updating to 1.2.0.16 and performing a factory reset. I verified that after downgrading to 1.0.2.138, everything works fine, but I was automatically upgraded again last night and it re-broke my setup, and performing another factory reset still doesn't enable Ethernet connectivity. Has anyone had persisting Ethernet issues after a reset and an upgrade to 1.2.0.16?
You need to apply the do not update, if not it will still update.
I would go to the support page and download the file from there and install manually.
Reset and test.
