PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Newfiedrool
Dec 21, 2020Virtuoso
Could you try downloading the update via the support page and try install manually then performing a factory reset.
Crtfdgk
Dec 21, 2020Star
Yep - all of my upgrades and downgrades (except for the very first one that was an auto-upgrade) have been done via the web interface and the .img downloaded from support.
- NewfiedroolDec 21, 2020Virtuoso
What we did notice was when I compared mine to my friends there was a lot more memory used compared to his. I turned my router off for 15min as he did and that cleared the memory.
worth upgrading, reset, setup, turn off router and leave then turn on and see what happens.
- soeunDec 21, 2020ApprenticeSo another odd thing I’ve noticed is that the wired connections that don’t work are windows PC. My Synology NAS which is wired works fine. I can connect to it. Will test out MacBook shortly via Ethernet shortly .
- soeunDec 21, 2020ApprenticeNvm. Synology NAS unable to access internet. :(
