PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Killhippie
Dec 22, 2020Prodigy
Please do not assume you know the reason I turn my router off. Its done so all my logs start zeroed from boot which is how I have always done my updates and is a personal thing. Also it clears the cache and you will notice that RAM useage drops after a power down with the power supply removed for about 10 minutes. If this was such a myth why do Sony suggest to do this to clear the cache on Android TV's and the cache on PlayStations!
As far as a pin hole reset I take it you have not read R Merlins report on factory resetting? This person has his own Asus fork on smallnetbuilder and also patches for Asus themselves with many years of doing this behind him, so excuse me if I belive him over you. Here is a link that may be helpful about factory resets.
https://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
As far as the current firmware there has been a change in the QCA SDK I cannot talk anymore about this as I am under a NDA. I have factory reset my router, set it up from scratch and all ports work, I also powered it down as usual to clear the cache and reset all the logs (personal choice on powerdown) The issue with the ports is a known one and a reset or re-downloading the firmware then logging out after updating and resetting should sort the issue out. If it does not please contact Netgear support.
webder
Dec 22, 2020Star
I assumed nothing about you, you've contribute minimally to the thread and certainly nothing since I started reading.
Powering off versus powering off 'for 15 minutes' are two entirely different things and I made no such claim on the former. Powering off and even soft resetting in most cases (where firmware is appropriately configured) will zero logs and perform other beneficial functions, believing powering off for 15 minutes does anything contrary to this is ridiculous and I beg you go claim such to anyone with an electrical engineering degree.
Clearing NVRAM isn't even being discussed and this can be mitigated from within firmware.
Come on guys, all the rest of us are doing is highlighting a problem with the firmware and even discussing where it may lie. If you don't want to join the discussion that's fine, otherwise your solutions are somewhat rudimentory and non viable to the rest of us.
