PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
gear1978
Dec 23, 2020Tutor
It's a bad experience to upgrade my rax120 with the firmware 1.2.0.16 on day one, only couple hours after I opened the box and started to use... it was working perfectly for first couple hours with fw 1.0.2.136, then all wired ports (NAS, desktop) lost internet connection right after the new fw1.2.0.16 installed automatically, reset and setup from scratch doesn't work at all, I have to roll back to fw1.0.2.136 and everything goes back to normal.
For the previous 6 years I was ASUS user until recently I wanted to hook up my NAS by Lan ports aggregation and my PC by 2.5G port. RAX120 seemed to be a good choice but I never expected such experience on day one... the worse thing is still no new firmware released after we discussed here for almost one week.
Was it a wrong decision to buy this router?
- NewfiedroolDec 23, 2020Virtuoso
Go to support page, download, update and reset then pop back and let us know how it goes.
- gear1978Dec 23, 2020Tutor
Actually I've tried it. The first reset applied after it installed the new fw automatically, then I downloaded the firmware under support page and installed again, applied another reset and setup, same result.
As it's a new router your best bet is to take advantage of free support.
