PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
TrumpKing
Dec 24, 2020Aspirant
My RAX120 didn't reboot continually until a week after I installed new firmware 1.2.0.16. It started to reboot repeatly yesterday evening, so I came here to report this issue.
Here is my case: the new firmware works fine in the first week but get a malfunction (reboot repeatly) then. That means those RAX120 routers which perform normal currently may also encounter functional failure in the future.
Currently, I tried to both software and pinhole reset, both can't help. The only solution is to roll back to firmware 1.0.2.136, and everything works fine then.( it also proves that my RAX120 hardware has no problem)
I hope NETGEAR can release a new firmware soon after Christmas.
