PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
TrumpKing
Dec 24, 2020Aspirant
My RAX120 didn't reboot continually until a week after I installed new firmware 1.2.0.16. It started to reboot repeatly yesterday evening, so I came here to report this issue.
Here is my case: the new firmware works fine in the first week but get a malfunction (reboot repeatly) then. That means those RAX120 routers which perform normal currently may also encounter functional failure in the future.
Currently, I tried to both software and pinhole reset, both can't help. The only solution is to roll back to firmware 1.0.2.136, and everything works fine then.( it also proves that my RAX120 hardware has no problem)
I hope NETGEAR can release a new firmware soon after Christmas.
Newfiedrool
Dec 24, 2020Virtuoso
As been out for a week and as you don't know it will happen again your best bet is to update again, reset and monitor for another week.
as the process was easy for you to solve there is no harm trying again.
- TrumpKingDec 24, 2020AspirantI tried to downgrade and upgrade to 1.2.0.16 several times and also pinhole reset. It still can’t work as normal as before, quite weird.
- AVLTechDudeDec 24, 2020Tutor
Netgear needs to flush this t*rd, pull it from distribution, and focus on the next version and an effective test plan for it as well. Wrong time to autobrick a bunch of essential work from home equipment, Netgear. Move it forward please.
- DealMay 05, 2021Tutor
You don't mention what firmware version you're having trouble with, nor what the troubles are that you are having. That would be helpful to know to see if I have any of those issues. I just got the RAX120 and am just learning of issues, but it's been difficult to tell exactly what the issues folks are seeing. This would help in the process of elimination of what the causes of "strange" events on my network are.
Thanks
David
- TrumpKingDec 27, 2020Aspirant
Update: I went through the update log again carefully and found that NETGEAR updated the interface of Traffic Meter. I tried to disable the Traffic Meter and clear the data usage history on my RAX120. Everything works perfect then. The main reason I guess should be Traffic Meter interface, the system could crash when accumulated data usage reaches a certain value, and that can explain why my RAX120 didn't get a malfunction until after a period of use.
