PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
kc6108
Dec 25, 2020Luminary
Also forgot to mention I performed the curl commands (http then https) on both my LAN and my WLAN. No errors. All success.
webder
Dec 25, 2020Star
Thanks kc6108. Interesting and quite the impressive config. I'm utilising LAG on port 1-2 of the RAX120 itself, and a couple of other devices on the other LAN ports, which could indicate bypassing the ports is an effective workaround.
Also, do you have to tag VLAN on your WAN side? Generally you don't for cable connections, and as you mention you're using a MB8600 and bypassing the modem functionality of the RAX120. But this seems to be another common trait among those experiencing issues with the LAN ports, and unfortunately still hasn't been addressed by Netgear.
