PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Crtfdgk
Mar 20, 2021Star
Has anyone who needs to configure VLAN tagging for their ISP had success with getting wired clients connected on 1.2.0.16? Has anyone been able to contact Netgear about this specific issue? It seems strange that I would need to pay $50 just to report an issue that is specific to an update, and since there’s no acknowledgement we don’t even know if the next update will include a fix.
Crtfdgk
Mar 23, 2021Star
Although it’s still listed in the downloads page, the Nighthawk iOS app has stopped prompting me to install the 1.2.0.16 firmware (as I’m currently still on 1.0.2.136). The firmware update checker web UI has also stopped indicating 1.2.0.16 is available. Can anyone still on an older firmware verify if this is the case for them as well? Makes me wonder if this latest update has been pulled from the auto-update channels.
- pc74Mar 23, 2021Aspirant
Crtfdgk wrote:
Although it’s still listed in the downloads page, the Nighthawk iOS app has stopped prompting me to install the 1.2.0.16 firmware (as I’m currently still on 1.0.2.136). The firmware update checker web UI has also stopped indicating 1.2.0.16 is available. Can anyone still on an older firmware verify if this is the case for them as well? Makes me wonder if this latest update has been pulled from the auto-update channels.I'm also on 1.0.2.136 and not getting the prompt to upgrade anymore.
- mondenathMar 25, 2021Prodigy
Can any one confirm if 160Mhz works on ac and ax simultaneously or only ax or ac at a time or limited to ax only.
- soeunMar 29, 2021Apprentice
I still get prompted for the update. They haven't pulled this firmware and doesn't look like they will. Still waiting for the next one. Don't think i'll be sticking with netgear when my next upgrade comes around.
- CrtfdgkMar 29, 2021StarI checked and I’m now being prompted to update again - seems like it was only temporarily unavailable.
