PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
AVLTechDude
Dec 24, 2020Tutor
Netgear needs to flush this t*rd, pull it from distribution, and focus on the next version and an effective test plan for it as well. Wrong time to autobrick a bunch of essential work from home equipment, Netgear. Move it forward please.
Deal
May 05, 2021Tutor
You don't mention what firmware version you're having trouble with, nor what the troubles are that you are having. That would be helpful to know to see if I have any of those issues. I just got the RAX120 and am just learning of issues, but it's been difficult to tell exactly what the issues folks are seeing. This would help in the process of elimination of what the causes of "strange" events on my network are.
Thanks
David
- soeunMay 11, 2021Apprentice
New Firmware came out. Mine auto updated last night at 3AM. After update, all my wired connections stopped working. Wireless connections continued to work. Same issue as last firmware with VLAN Tagging and PPPoE. However, I tinkered around and created a new VLAN Tag group and enabled only the physical ports and same VLAN ID as previous. That did not work when I applied so I deleted the newly created VLAN Tag group and hit applied and all of a sudden all wired connections started working again. Hope this helps with anyone dealing with Centurylink, PPPoE and VLAN Tag requirements.
- webderMay 14, 2021Star
soeun you absolute legend. I've managed to replicate your fix and it's applicable for me too (non Century link, but Aus internet provider with VLAN tag). Not too difficult, but of course you have to apply each time upon creating and deleting the new VLAN tag group, and be prepared for almost everything to break when creating the test VLAN tag group for wired devices only. Nice work mate, saved me a lot of time on further trial and error (or giving up).
If anyone from Netgear is reading this - your GUI/auto setup of VLAN tagging is broken (even when factory resetting), please look into it or at least acknowledge it for the not insignificant number of people who require it. - gear1978May 17, 2021Tutor
Thank you Soeun, you are the man! Your solution works on mine with the latest fireware V1.2.1.22!!
- Match4208May 20, 2021AspirantWould like to know is there have other critical issue of the latest FW 1.2.1.22!
PS I’m using RAX120 with FE 1.2.0.16
Thanks
