BJ888
Mar 01, 2021Follower
D-Link wifi extender with Netgear RAX45
I recently replaced my D-link router with a Netgear AX4300 Model#RAX45 I had a D-link wifi extender (DAP 1330) that I had been using to boost the signal out to a room farther from the router. Once ...
Mar 01, 2021Guru - Experienced User
You can try a factory reset on the dlink extender.
but you might get more help on the dlink forum for how to setup their extender.
