erlo206
Oct 24, 2021Tutor
Daylight saving issue RAX70
Hi all, I am in Auckland New Zealand. My TZ is GMT+12:00 with daylight saving now. I tick "Automatically adjust for daylight saving time". It doesn't apply daylight saving on the RAX70. I tr...
mclemens
Nov 07, 2021Guide
As in my above post, my internet keeps disconnecting possibly just like it does for people in the other thread https://community.netgear.com/t5/Orbi/Daylight-Savings-Time-NTP-DNS-Issues/m-p/2073929.
Seems that DST issue causes the DNS issues, so once a day for a week my internet is disrupted every morning.
I find this issue is important enough when my internet connectivity gets disrupted every time DST changes twice a year, every year, and I have to fiddle with time zone settings as a work around. I've had this disruption last a week, and now that DST actually changed, the router's time and actual current time are synced up. I think we can expect this to recur until a firmware fix comes out.
As for the other alternative that was suggested in this thread, I'm not sure that it's possible to return my router at this time. I'd rather have it fixed and not have to go shopping around for another router, especially since it's not unfair to expect an expensive mesh router to work out of the box.
erlo206
Nov 07, 2021Tutor
Another workaround is you have to change the TZ manually to match your real time. I changed to GMT+13 instead of GMT+12 during daylight saving.
- mclemensNov 08, 2021Guide
Thanks erlo206, I changed my timezone as a workaround and it was stable after that, then once real DST date arrived, I switched it back to my normal timezone. No connectivity issues during synced up time (via workaround, and subsequently when DST date arrived as per above).
Also, in some other threads it was mentioned to turn off traffic meter - mine was already off, so couldn't have been that.
I hope a new firmware version is released at some point to fix DST so that it starts and ends at the right date-time. Or if they could add a feature to enter our own date-times for starting/ending DST which I had on an older competitor's router.My setup:
Firmware Version V1.0.6.116_2.0.54 for Nighthawk MR60
- FURRYe38Nov 08, 2021Guru - Experienced User
Since you have the NH Mesh MR60 system, Please post about this over in the following forum:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Also contact NG support and let them know what your seeing and what happen before and after the time change transitioned this past Sunday morning. They won't fix what they don't know about.
Thank you.
