erlo206
Oct 24, 2021Tutor
Daylight saving issue RAX70
Hi all, I am in Auckland New Zealand. My TZ is GMT+12:00 with daylight saving now. I tick "Automatically adjust for daylight saving time". It doesn't apply daylight saving on the RAX70. I tr...
mclemens
Nov 07, 2021Guide
As in my above post, my internet keeps disconnecting possibly just like it does for people in the other thread https://community.netgear.com/t5/Orbi/Daylight-Savings-Time-NTP-DNS-Issues/m-p/2073929.
Seems that DST issue causes the DNS issues, so once a day for a week my internet is disrupted every morning.
I find this issue is important enough when my internet connectivity gets disrupted every time DST changes twice a year, every year, and I have to fiddle with time zone settings as a work around. I've had this disruption last a week, and now that DST actually changed, the router's time and actual current time are synced up. I think we can expect this to recur until a firmware fix comes out.
As for the other alternative that was suggested in this thread, I'm not sure that it's possible to return my router at this time. I'd rather have it fixed and not have to go shopping around for another router, especially since it's not unfair to expect an expensive mesh router to work out of the box.
Nov 07, 2021Guru - Experienced User
IF this is happening all the time, then It may NOT be anything releated to NTP or time services. You may have other issues.
Something that maybe with our help might be able to help you narrow it down farther to see if it's a router, FW or something else. Those issues were specific to Orbi systems an not releated to other router lines. That issue was resolved in a FW update for the Orbi 50 series system.
