jtlynn23
Jul 09, 2020Tutor
Dead Nighthawk RAX35 - Support Ticket Open, Netgear Unresponsive
I have a RAX35 router that will not broadcast at all. I get a power light and nothing else. I opened a service ticket with Netgear Support at www.support.netgear.com. I got a quick response fro...
- Jul 09, 2020
have you tried recovery via tftp?
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
another thing to check into is many don't use the proper netgear support. They google and get the wrong site/scam site.
click mynetgear at the top. register an account and the device. From there you contact support.
If that's what you did, maybe a moderator can help. Christian_R olympos1625
Jul 09, 2020Guru - Experienced User
