mox575
Aug 08, 2024Aspirant
Degraded Ping Time on Latest Firmware
I just unboxed my new RAX30. Went into the router software and changed my DNS servers(OpenDNS) and set up my WiFi. This was on Monday. Wednesday my Ping time dropped significantly, from 4-6ms to 18-...
mox575
Aug 20, 2024Aspirant
Thanks for the response. Good to know that it isn't just my unit. I haven't had a chance to contact Support, too much going on right now and it's seems to run ok on the older firmware. So for now, I will stick with what works. Hopefully it will be corrected in the next update.
Aug 20, 2024Guru - Experienced User
Be sure to reach out to NG support and let them know about this.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Good luck.
