Fritzscorner321
Dec 02, 2020Aspirant
Desktop PC won’t connect to RAX 75 5ghz
My desktop pc wont connect to the 5 GHZ band of my RAX 75 router. My new pc is using a tp link ax3000 pcie card. Previous pc was using a ubit ax card and wouldnt connect either. Both running intel ax ...
Dec 02, 2020Guru - Experienced User
What driver version is the AX200 on?
Fritzscorner321
For intel ax 200 i am currently running verison:
22.0.0.6
I have tried previous driver versions already on my previous desktop pc using the ubit wifi 6 card and it didnt work.
For nighthawk router im using verison 2.7.0.27.
- Fritzscorner321Dec 02, 2020AspirantCorrection...
Nighthawk router is on 1.0.3.102- plemansDec 03, 2020Guru - Experienced User
Does it connect if AX is disabled on the router?
Have you factory reset the router and reinstalled it?
- Fritzscorner321Dec 05, 2020Aspirant
With AX disabled on the router it still does not connect.
Doing a router reset hitting the reset button on the back and going through the setup process did not fix anything either.
Intel had new drivers for ax200 also I noticed this morning.
Update drivers to 22.10.0.7 and still no internet access on 5ghz network with my desktop.
