Fritzscorner321
Dec 02, 2020Aspirant
Desktop PC won’t connect to RAX 75 5ghz
My desktop pc wont connect to the 5 GHZ band of my RAX 75 router. My new pc is using a tp link ax3000 pcie card. Previous pc was using a ubit ax card and wouldnt connect either. Both running intel ax ...
Fritzscorner321
Dec 05, 2020Aspirant
With AX disabled on the router it still does not connect.
Doing a router reset hitting the reset button on the back and going through the setup process did not fix anything either.
Intel had new drivers for ax200 also I noticed this morning.
Update drivers to 22.10.0.7 and still no internet access on 5ghz network with my desktop.
Dec 05, 2020Guru - Experienced User
It makes me suspicious of the card. I know there was a different device with issues but you don't have that one to test anymore.
I have an intel AX200 and and AX210 and they both connected.
The AX200 I got when drivers were still new and it had issues, disabling AX would allow it to connect and there was a pretty quick firmware change and it worked with AX after that.
Other than the 1 other, all of your other 5ghz devices work?
- Fritzscorner321Dec 05, 2020Aspirant
Just took my xfinity wifi modem/router out of bridge mode and tested that 5ghz connection and it works perfect with ax connection also. Think im going to return the netgear router back to costco look into a different one.
