a-nish's avatar
a-nish
Follower
Jul 14, 2021
DEV devices showing up on RAX-45
Hi all--have RAX 45 WIFI 6 router that has started to show up DEV-XX:xx:xx devices with MAC ids that are not found in an MAC databases
Please see the attached image
can someone provide the root cause and work around if any
Thanks
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello a-nish,
    Can you provide the firmware version your router is currently on? I would recommend checking for a firmware update and reinstalling the Nighthawk app.
    Christian
