LLH1956
Aug 26, 2023Aspirant
Device Connection Issues
I have a RAX70 router and have had no issues until replacing the router from the cable company. It’s a SERCOM model DM1000. Devices will no longer stay connected to the router. Do I have to reset rout...
michaelkenward
Aug 26, 2023Guru - Experienced User
LLH1956 wrote:
It’s a SERCOM model DM1000. Devices will no longer stay connected to the router. Do I have to reset router?
Not sure what you see when the connection goes down, but that looks like a standard modem only device.
With a new network, it makes sense to reset the router and set it up for the new modem.
LLH1956
Michael - Sorry, I should have said I replaced the cable company modem, which is the Sercomm. The router is the same.
- michaelkenwardAug 27, 2023Guru - Experienced User
LLH1956 wrote:
Michael - Sorry, I should have said I replaced the cable company modem, which is the Sercomm. The router is the same.That is how I interpreted your explanation.
The answer is the same.
The router sees a different modem. You need to set it up to work with that modem.
That may not solve the problem you see, but without doing that you will never know.
In any case, a reset is one of the first things that you will be advised to do when you have problems.
- LLH1956Aug 27, 2023AspirantI tried the router reset but devices continue to lose WiFi connection.
- michaelkenwardAug 28, 2023Guru - Experienced User
LLH1956 wrote:
I tried the router reset but devices continue to lose WiFi connection.Before anyone can begin to diagnose that sort of issues, they need more detail, beyond "lose WiFi connection". That could be down to many many different things.
What happens? Error messages on the wifi clients?
What do the LEDs on the RAX70 router show? (Especially the wifi LEDs.)
How do you know that the router is the problem rather than the wifi clients?
What are these wifi clients? iOS by any chance?
What firmware is installed on the RAX70?
