anthonyng5p
Nov 22, 2020Apprentice
Device intermittently disconnect on RAX50 wireless router
I have been using my Netgear RAX50 Wifi6 router for about a couple of months now. I have problems where certain devices lose their connection, and intermittently disconnect. Sometimes the devices rea...
- Dec 20, 2020
I just wanted to follow-up on this thread, since the recommendation was to use static IP addresses for the affected devices. The DropCam and the Lyric sensors have not experienced a problem since being assigned IP addresses. There has been no instances of devices losing IP connectivity. The PS4 is still a problem but it seems that may be unrelated.
anthonyng5p
Nov 29, 2020Apprentice
I received some feedback from Netgear support and I am going to try and allocate IP addresses the the devices that are misbehaving. However, this probably will take a week or so to see if there are any changes. I only changed one of the devices, the Dropcam, because it is always online and easily managed. Previously, the problem would be such that things would seems fine for a while, then there would be a flurry of problems over a couple of days. We shall see. I am still running without AX mode and allowing WPA/TKIP.
anthonyng5p
Dec 20, 2020Apprentice
- anthonyng5pJan 03, 2021Apprentice
I did see the problem reoccur for the Nest DropCam. There is something wierd about the DHCP and its interaction with this specific device. I feel like there is some kind of software bug here; unplugging the DropCam, waiting for 20 mins, and then powered-on did not work this time. I have not had any further problems with the Lyric water sensors since the last post.
