gundoc
Aug 13, 2021Follower
device management / band use
Hello,
I am trying to isolate devices and assign them to work with the 2.4 band only and have all other devices utilize teh other 2 5Ghz bands. I am having trouble identifying which device is which on the app they are described as "nwetwork" and everythign is using the 2.4Ghz band causing extremyl slow speeds.
Please any advice.
thank you!
1 Reply
You can disable smart connect so you can choose which to connect to.
