joe_wht
Dec 05, 2019Luminary
Device Priority Nighthawk RAX200 AX11000
-- DANG -- I "THOUGHT" I had posted this SEVERAL DAYS AGO ! I've been checking back(looking at the notification bell thingy) for an answer 3 to 4 times a day... NOW, I open my profile to find it un...
microchip8
Dec 06, 2019Master
I think you need Advanced QoS to set device priority. Adaptive QoS doesn't do that. I don't know which QoS they ship with the RAX200
OFDMA is not fully supported yet, neither on BCM or QCA devices. There's partial upload support on QCA ones like the RAX120 but they won't see full support as it needs newer hardware. NG might release a v2 of the RAX120. The RAX200 is BCM based which is even worse than QCA as BCM is behind it atm.
Which is better? QCA, of course. It has dedicated network offload processors in its SoC as opposed to relying on CTF like BCM does, and CTF is not compatible with anything that needs to inspect packets first so it gets disabled.
