BrentW1975's avatar
Dec 28, 2019
Devices can’t find WiFi router on available networks
Some devices in my home can’t find our WiFi on available networks list. I recently installed a nighthawk AX4 WiFi 6 router. I can find and connect to the internet on our phones, laptops, gaming device...
  • plemans's avatar
    Dec 28, 2019
    Try disabling wireless AX. Some of the older devices are struggling.
    Disable the AX and then reboot the router. See if this works.
