BrentW1975
Dec 28, 2019Guide
Devices can’t find WiFi router on available networks
Some devices in my home can’t find our WiFi on available networks list. I recently installed a nighthawk AX4 WiFi 6 router. I can find and connect to the internet on our phones, laptops, gaming device...
- Dec 28, 2019
Try disabling wireless AX. Some of the older devices are struggling.
Disable the AX and then reboot the router. See if this works.
BrentW1975
Dec 28, 2019Guide
I may have been too hasty. Rebooted the router again and waited awhile. Now the 2.4 GHz network shows up (never did before) and I can use that network to connect the old devices.
Thanks a lot!!
Thanks a lot!!
Dec 30, 2019Guru - Experienced User
Glad to hear you got it working!
