CodySF57
May 05, 2021Aspirant
Devices Connected to Internet but say "No Internet"
Model: RAX10 (For some reason can't select that one in the list) Firmware: v1.0.3.92 (shows as current on the Nighthawk App and website last I checked) I got this router a few days ago and set i...
- May 06, 2021
which is a modem/router combo device.
It can cause a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
How to fix issues with Double NAT | Answer | NETGEAR Support
CodySF57
May 06, 2021Aspirant
BGW210 from AT&T.
I
May 06, 2021Guru - Experienced User
- CodySF57May 06, 2021Aspirant
Ah thank you, didn't even think about that. I'll work with my ISP to setup the bridge mode on my modem.
- CodySF57May 10, 2021Aspirant
Went ahead and changed my Modem/Router into bridge mode and logged into the router using the web address opposed to the Nighthawk app.
Everything is working on my router and it is showing online.
Thank you.
