darkjfman
Sep 09, 2021Tutor
Devices lose connection randomly on main WiFI
I have been having problems with devices not being able to connect to my Main WiFi, as a result I sometimes connect them to the Guest wifi when multiple attempts to get them to connect to the main on...
darkjfman
Sep 09, 2021Tutor
I currently have ARRIS SURFboard SB8200 DOCSIS 3.1 as my modem.
The range extenders have been setup through the nighthawk app to "extend" my Main WiFi, is there a way to determine if it's a Daisy or Star configuration?
With the router alone, my deadspot are amplified and responsivness is decreased tremendously to the point where in my bedroom it's almost useless to use WiFi. The house is 2400 SqFt, so the RAX80 should be sufficient based on the description.
darkjfman
Sep 09, 2021Tutor
Took a minute the app to display all of them, it is a star configuration. The main router is sending signal to both individually.
