Jayhawkeye3
Aug 17, 2019Tutor
Devices won’t connect?
Hello! Hoping someone can help me out, as I’m definitely not smart when it comes to these types of things. I recently purchased an AX8 router and installed it in my home, which has U-verse cable an...
michaelkenward
Aug 18, 2019Guru - Experienced User
Jayhawkeye3 wrote:
I recently purchased an AX8 router and installed it in my home, which has U-verse cable and gigabit service.
Is that the RAX75 or RAX80? Both are "AX8".
Jayhawkeye3 wrote:
We set the modem to AP mode and used the smart connect setting to combine the 2.4 and 5 channels.
What is this "modem"?
Modems don't usually have an "AP" mode. That is a way of using a router in a different mode. (You can use some modems as an AP, but then they cease to be modems)
Some wifi devices have a hard time living with 2.4 GHz and 5 GHz on the same SSID. This is down to the people who wrote the routine it takes to connect. They "forgot" to design their kit for the increasingly popular use of "mesh" wifi.
Some people turn off 5 GHz temporarily, connect to the 2.4 GHz and then turn the 5 GHz back on. Or they temporarily use separate SSIDs.
In fact, my work laptop doesn’t even show my home network as an available network!
Do you mean the laptop cannot see the wifi?
If it is a Windows laptop, it may think you are joining a "public" network.
You may need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
- Jayhawkeye3Aug 18, 2019TutorYes it’s the AX80.
Sorry, I mean we have the netgear set to AP mode. It’s hard wired to the U-verse router, but we have the WiFi on the U-verse disabled, So the only WiFi signal in the house is coming from the netgear.
The reason I turned both 2.4 and 5 back on is because when I had them combined using the smart WiFi netgear setting, many devices dropped altogether and could not reconnect.
Now when I have both signals available, the arlo can connect to 2.4, the Vivint can connect to 5, etc. however, after a day or so they all drop again.- Jayhawkeye3Aug 18, 2019TutorAlso, on my windows laptop, the settings are fine. I’m able to connect to other private WiFi networks with no issues. For my WiFi however, the laptop doesn’t even see it as an option.
Also, our home google is now completely down. Was working just fine yesterday and now can’t connect to the internet.
Essentially what I’m seeing is this router is slowly booting off various devices after I have them set up and working for a few days.- kemcroAug 18, 2019Guide
Essentially what I’m seeing is this router is slowly booting off various devices after I have them set up and working for a few days.Your experiencing the same issues most of us are having with the RAX80, mine has been collecting dust waiting for a firware update that addresses the connection stability issues that plagues this device. If I wasn't beyond the return period I would return it in a heartbeat.
