darklink2368
Mar 11, 2024Aspirant
Devices Won't Connect after Router Reboot
I'm having this issue where I've rebooted and reset my router but my devices won't be able to connect to it and it just shows that there is no internet. I've also tried resetting my modem and same th...
Mar 11, 2024Guru - Experienced User
What brand and model# devices do you have all connected at once?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
MAC Address Randomizers:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
What channel configurations are currently set on the router? And Advanced settings?
Is Smart Connect enabled or disabled?
