james2021
Mar 15, 2021Follower
Difference between AX1800 model# RAX10 and AX1800 model# R6700AX
Hi, Could someone please explain what's the difference bettween Netgear router model RAX10 and model R6700AX ? I tried Google but got no answer. Both are the same identical to me, I bought RAX10 ins...
- Mar 15, 2021
Some of the newer netgear router don't have parental controls. They *might* get them but nothings been confirmed/released yet.
The R6700 (there isn't an AX version) is a midlevel AC router.
AC1750 (450Mbps @2.4GHz + 1300Mbps@5GHz 11ac)
The RAX10 is a base model AX router.
- 2.4GHz: 600Mbps, 40/20MHz1024/256-QAM
- 5GHz: 1200Mbps, 80/40/20MHz 1024-QAM
Mar 15, 2021Guru - Experienced User
- antinodeMar 15, 2021Guru
