bballdak12
May 14, 2020Aspirant
Difference between RAX15 and RAX20? AX1800
Looking at the Ax1800 wifi 6 router Whats the difference between the Rax15 and Rax20? I see that on Netgear's website the Rax20 is more expensive but I can't find a difference between the two....
bballdak12
May 15, 2020Aspirant
Not the 200
I'm still referencing the AX1800
They have two models for it. One is a RAX15 and one is a RAX20
May 15, 2020Guru - Experienced User
If you look up the RAX15 and the RAX20 with the fcc report, they're identical. The naming difference is marketing.
sorry, read to fast and read rax200 not rax20.
