daniostr
Sep 03, 2020Aspirant
Different wifi speed on Nighthawk app and Browser
Hi everyone, I recently bought Netgear RAX20 AX1800 router, On my Nighhawk app speed test I apparently recieve about 900mbps. But when I check my speed on speetest webstie using google chrome ...
Sep 04, 2020Guru - Experienced User
daniostr wrote:So how i nacexplain this massive drop in speed.---Maybe with more details?
Even on Lan connection I recevie only 240 mbps,
On 5 ghz I recieve around 120 mbps.
Is it just a bad router, should I replace it?
what device are you testing on via lan?
What website are you testing the speed on?
What firmware are you on?
What modem is it connected to?
do you have access control, parental controls, qos, and traffic monitoring all disabled?
Actual details help. You first asked why you see a speed different and then gave minimal info afterwards. We need details about what your setup is, how your testing, what settings you're using, etc.
daniostr
Sep 05, 2020Aspirant
what device are you testing on via lan? - DELL LATITUDE E7450
What website are you testing the speed on? Speedtest app
What firmware are you on? V1.0.1.64_2.0.41
What modem is it connected to? Connected to D-LINK DMC G01LC optic bridge
do you have access control, parental controls, qos, and traffic monitoring all disabled? NO
- plemansSep 05, 2020Guru - Experienced User
Any other devices you've tried testing on?
have you tried a simply factory reset and reinstall?
- daniostrSep 05, 2020Aspirant
Yes, just now.
And I receive sround 280 mbps.
But the results in the nighthawk app is around 800~ mbps.
It is better but not very satisfying, should I replave the model?
Have you tried downgrading the firmware?
Or do you have ipv4/6 setup?
make sure access control is off as well.
- michaelkenwardSep 06, 2020Guru - Experienced User
What's that? One of these?
DMC-G01LC 1000BaseT to SFP Standalone Media Converter | D-Link UK
Doesn't look like a modem to me. Or even an optical network termination.
