daniostr
Sep 03, 2020Aspirant
Different wifi speed on Nighthawk app and Browser
Hi everyone, I recently bought Netgear RAX20 AX1800 router, On my Nighhawk app speed test I apparently recieve about 900mbps. But when I check my speed on speetest webstie using google chrome ...
Sep 05, 2020Guru - Experienced User
Have you tried downgrading the firmware?
Or do you have ipv4/6 setup?
make sure access control is off as well.
daniostr
Sep 05, 2020Aspirant
downgraded firmware
Or do you have ipv4/6 setup? no
access control is off.
When I plug the lan directly from the modem(bridge)
I recevie 900 mbps. I don't understand why the router losses so much speed.
- daniostrSep 05, 2020Aspirant
Also when I define the VLAN/bridge in router I receive on LAN connection around 900~ but than the wifi isn't working
