greywardens1
Nov 18, 2022Aspirant
Disable ipv6 dhcp internally
I'm trying to use an internal dns and dhcp server(adguard), and the ipv6 dhcp won't disable on the cax80. Is there a new firmware that allows for this? uPNP is on, and there is nowhere to turn off i...
Nov 19, 2022Guru - Experienced User
On the combo devices, its the ISP that controls it.
I've only found it on the router only devices where the user can manage it.
