Tim9449
Mar 01, 2021Follower
Disable Wireless Isolation on RAX80
I need to disable wireless isolation on my router according to Logitech so that a Harmony Remote Hub can be set up. Not sure how to do this.
- Christian_RNETGEAR Employee Retired
Hi Tim9449,
I would recommend checking out an older post that may help resolve your issue.
Christian
- GabboCHApprentice
Not really sure that turning off SmartConnect is a "solution" rather a "workaround" for a problem in the netgear routers..?
