Ann743
Feb 11, 2025Aspirant
Disabling WPS in RAX54S
Does anyone know how to disable WPS in the RAX54S either directly or indirectly if there is such a way like disabling a pin? I do caregiving & sometimes take in people with disabilities whose caregi...
Feb 12, 2025Guru - Experienced User
I'd agree with it being a big of a security risk. There used to be a way to disable it. I don't see it on my rs600 or any of my orbi's. Could be a feature that's been removed. Might suggest re/enabling it on the ideas exchange forum.
I believe that WPS is not active until any WPS button is pressed.
Something to ask NG about though.
- plemansFeb 13, 2025Guru - Experienced User
You're a little caught. If they have access to hit the wps button, they also have access to the ethernet ports which gives them access to. Locking it in a cabinet or even a plastic case is about your only option
- Ann743Feb 22, 2025Aspirant
Yeah, I think I'm going to have to find some way to lock it up. May be tricky with the wires & antennas, but I'll try to think of a way. Thank you all. And I apologize for taking so long to get back. I did just recently had someone staying for awhile, so my free time went way down for a bit.
Almost forgot to mention I did read on the internet that its not possible to block all new connections & leave the guest network open to connect new devices. I haven't tested it out for myself. I suppose I could test it out just in case what I read is wrong.
