Ann743
Feb 11, 2025Aspirant
Disabling WPS in RAX54S
Does anyone know how to disable WPS in the RAX54S either directly or indirectly if there is such a way like disabling a pin? I do caregiving & sometimes take in people with disabilities whose caregi...
Feb 12, 2025Guru - Experienced User
I believe that WPS is not active until any WPS button is pressed.
Something to ask NG about though.
Feb 13, 2025Guru - Experienced User
You're a little caught. If they have access to hit the wps button, they also have access to the ethernet ports which gives them access to. Locking it in a cabinet or even a plastic case is about your only option
