Whipsnade's avatar
Whipsnade
Disabling WPS
Is it possible to disable WPS on an RAX45 router?  I can find no such option anywhere in settings.
  • WPS is for people to connect to your local wifi network.
    They either have to press a button on your router an one on their device, or they have to start the process with a web browser and the graphical user interface (GUI).
    Typically, it is a simple way of connecting a printer to the router.
    This is not something that a stranger on planet Zog can break into. They have to be standing next to the router.
    Whipsnade wrote:
    I've read, "Its considered a security vulnerability primarily due to its susceptibility to brute force attacks and can be relatively easily cracked.  Also many routers do not enforce a lock-out policy after multiple failed attempts."
    I don't know where you read that. The terminally paranoid should look for a router that allows them to disable WPS or that does not support it. But it is not at the top of most people's list of security concerns.
  • michaelkenward's avatar
    michaelkenward
    Not that I know of. It comes up here from time to time.
    Out of interest, why do you want to do this?
    • Whipsnade's avatar
      Whipsnade
      I never use WPS. I've read, "Its considered a security vulnerability primarily due to its susceptibility to brute force attacks and can be relatively easily cracked.  Also many routers do not enforce a lock-out policy after multiple failed attempts."  I always disable it if I can.
        michaelkenward
