SniperStorm
Jul 04, 2022Tutor
Disapearing Port Forwarding Setting! What is the solution.
My RAXE500 Keeps dropping the Port Forwarding setting. I have 2 telnet servers running and a FTP server. Randomly they will just stop working for no reason. Then when I go into the settings for port...
Jul 05, 2022Guru - Experienced User
How are you configuring the PF rules?
Have you disabled uPnP prior to setting up the PF rules?
- SniperStormJul 05, 2022Tutor
Hello and thank you for the help.
What Firmware version is currently loaded? Firmware Version V1.0.8.70_2.0.36 It has been going on the last few versions also.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It has worked with my last 2 linksys routers. It is only affected by this router.How are you configuring the PF rules? With the normal port forwarding tab.
Have you disabled uPnP prior to setting up the PF rules? No.
This is what the screen turns into. The rules are there and working right now. You just cannot see them to edit them or access them. Next pic is what happens when you try to add or edit them.
- FURRYe38Jul 06, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It has worked with my last 2 linksys routers. It is only affected by this router. <So What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How are you configuring the PF rules? With the normal port forwarding tab.
Have you disabled uPnP prior to setting up the PF rules? No. <This should be DISABLED prior to setting up PF rules.
- SniperStormJul 06, 2022Tutor
Answer Hitron #en2251. This problem has existed with 2 different modems. If I set up my old LInksys router everything works fine.
I disabled it and it still does not work as it should.
