SniperStorm
Jul 04, 2022Tutor
Disapearing Port Forwarding Setting! What is the solution.
My RAXE500 Keeps dropping the Port Forwarding setting. I have 2 telnet servers running and a FTP server. Randomly they will just stop working for no reason. Then when I go into the settings for port...
SniperStorm
Jul 05, 2022Tutor
Hello and thank you for the help.
What Firmware version is currently loaded? Firmware Version V1.0.8.70_2.0.36 It has been going on the last few versions also.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It has worked with my last 2 linksys routers. It is only affected by this router.
How are you configuring the PF rules? With the normal port forwarding tab.
Have you disabled uPnP prior to setting up the PF rules? No.
SniperStorm
Jul 05, 2022Tutor
This is what the screen turns into. The rules are there and working right now. You just cannot see them to edit them or access them. Next pic is what happens when you try to add or edit them.
- SniperStormJul 05, 2022Tutor
- iyangJul 06, 2022NETGEAR Expert
What's port forward rule do you use ?
one rule for ftp, two rules for telnet ?
