SniperStorm
Jul 04, 2022Tutor
Disapearing Port Forwarding Setting! What is the solution.
My RAXE500 Keeps dropping the Port Forwarding setting. I have 2 telnet servers running and a FTP server. Randomly they will just stop working for no reason. Then when I go into the settings for port...
SniperStorm
Jul 06, 2022Tutor
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It has worked with my last 2 linksys routers. It is only affected by this router. <So What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Answer Hitron #en2251. This problem has existed with 2 different modems. If I set up my old LInksys router everything works fine.
How are you configuring the PF rules? With the normal port forwarding tab.
Have you disabled uPnP prior to setting up the PF rules? No. <This should be DISABLED prior to setting up PF rules.
I disabled it and it still does not work as it should.
SniperStorm
Jul 06, 2022Tutor
I just had to reload the setting for it to work again.
I wanted to upgrade to 6e. So I spent $500 on this router, now going to spend $350 on a LInksys. I have no idea why this is doing this over and over and I have not heard a peep from my support ticket.
- iyangJul 07, 2022NETGEAR Expert
- SniperStormJul 07, 2022Tutor
I added a few pictures. FTP, 2 Telnet, and one for OPEN VPN
- iyangJul 08, 2022NETGEAR Expert
Hi SniperStorm ,
Does it show correctly in port forwarding page for now ?
If yes, could you share the screenshot ?
Thanks
