H3FTA
May 28, 2020Aspirant
Disconnection Roulette
Bought myself a RAX200 to use instead of my VM SuperHub 4 (As apparently no one in VM Tech knows how to support their own kit) on the Gig1 plan. I seem to be playing disconnect roulette with all ...
Christian_R
Jun 02, 2020NETGEAR Employee Retired
Hi H3FTA,
May you disable AX and let us know if your issue persists. If you recently purchased your device, you may also contact our support team.
https://www.netgear.com/support/default.aspx
Christian
- H3FTAJun 02, 2020AspirantSorry but disabling the main reason for upgrading to this router is a bit backwards. It's been sent back to Amazon anyway.
