shadowb's avatar
shadowb
DLNA server not found from wifi devices on Access Point
My primary RAX50 is on one end of the house and the second RAX50 is in AP mode at the other end of the house connected via Ethernet cable.  I run Servio DLNA on a computer connected to the Prmary rou...
  • metroboulotdodo's avatar
    Aug 25, 2024
    Hi, this is my second answer:
    I search around and saw at the release of the predecessor Firmware 1-0-12-120 the issue "
    • Fixes the issue where multicast packet failed to forward between Wi-Fi and Ethernet clients."
    https://kb.netgear.com/000065385/RAX50-RAX50S-Firmware-Version-1-0-12-120
    I tested now by downgrading to this version: the problems encountered in my former post (and maybe connected to your problem) have gone.
    My guess: maybe the solved issue in 1-0-12-120 has been reopened in V1.0.16.132
