shadowb
Jul 16, 2024Aspirant
DLNA server not found from wifi devices on Access Point
My primary RAX50 is on one end of the house and the second RAX50 is in AP mode at the other end of the house connected via Ethernet cable. I run Servio DLNA on a computer connected to the Prmary rou...
- Aug 25, 2024
Hi, this is my second answer:
I search around and saw at the release of the predecessor Firmware 1-0-12-120 the issue "
- Fixes the issue where multicast packet failed to forward between Wi-Fi and Ethernet clients."
https://kb.netgear.com/000065385/RAX50-RAX50S-Firmware-Version-1-0-12-120
I tested now by downgrading to this version: the problems encountered in my former post (and maybe connected to your problem) have gone.
My guess: maybe the solved issue in 1-0-12-120 has been reopened in V1.0.16.132
shadowb
Jul 18, 2024Aspirant
What should I be looking for configuration wise? All I did was set mode to AP. Didn't change anything else except SSID and password.
Ethernet cable from Primary router is plugged into Ethernet port on AP router (I tried plugging into Port 1 with no difference).
I also tried making the SSID the same as the Primary - no help.
Which configuration settings are involved?
shadowb
Firmware levels the same:
AP router V1.0.16.132_2.0.92
Primary Router V1.0.16.132_2.0.92
