summsitsurf
Aug 10, 2023Aspirant
DMZ Set for NTRIP server but client will not connect
I have tried both DMZ and port forwarding to a windows desktop machine running an NTRIP server. Nothing will allow my client to connect. Any ideas?
Aug 10, 2023Guru - Experienced User
Contact the Mfr for this server product for help and information regarding there product.
- summsitsurfAug 10, 2023Aspirant
It worked before i upgraded to this router. I can’t ping the box either.
There are no entries in the log either on the router for anything attempting to hit that port i designated, 2101
- FURRYe38Aug 10, 2023Guru - Experienced User
What NG product model are you referring too?
Try a factory reset and setup from scratch on the router and see if anything changes.
Downgrade back to what had been working?
