summsitsurf
Aug 10, 2023Aspirant
DMZ Set for NTRIP server but client will not connect
I have tried both DMZ and port forwarding to a windows desktop machine running an NTRIP server. Nothing will allow my client to connect. Any ideas?
summsitsurf
It worked before i upgraded to this router. I can’t ping the box either.
summsitsurf
There are no entries in the log either on the router for anything attempting to hit that port i designated, 2101
- FURRYe38Aug 10, 2023Guru - Experienced User
What NG product model are you referring too?
Try a factory reset and setup from scratch on the router and see if anything changes.
Downgrade back to what had been working?
- summsitsurfAug 10, 2023Aspirant
Ax1800
AX1800 is not a model#. It's a wifi speed.
