summsitsurf
Aug 11, 2023Aspirant
DMZ Set for NTRIP server but client will not connect
I have tried both DMZ and port forwarding to a windows desktop machine running an NTRIP server. Nothing will allow my client to connect. Any ideas?
summsitsurf
Aug 12, 2023Aspirant
Ok firmware is the latest version, checked August 11th 2023.
I was trying to eliminate the R6700 as the issue here by going straight to the cable modem. Internet seems to work as expected but when my client tries to connect to the NTRIP server it times out.
Ethernet connection not wifi. No firewall on windows. Auto DHCP.
I will start troubleshooting the NTRIP server software. Apologies for assuming it was the R6700
michaelkenward
Aug 12, 2023Guru - Experienced User
Sounds like you succeeded there. The R6700 isn't involved, so worrying about its DMZ is a red herring.
You do realise that the R6700 is an old (2014) and not very capable router?
- summsitsurfAug 13, 2023Aspirant
I was not aware. What do you recommend?
- michaelkenwardAug 13, 2023Guru - Experienced User
Whatever meets your needs.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
If NTRIP is important to you, seek advice from people who understand how it works. They may be able to recommend a router that is known to work with it.
