temmet
Feb 06, 2021Aspirant
DNS and Printer problems RAX80
Client OS: Windows 10 64 bit Router: Nighthawk RAX80 Router firmware: V1.0.3.106_1.0.50 Purchase Date: 12/20/2020 Printer: Brother HL-L2380DW I am ready to take a bat to this router and live ...
temmet
Feb 07, 2021Aspirant
michaelkenward wrote:Is this a wifi connection from the printer to the router?
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
The printer software didn't detect the printer, but I was able to manually configure the IP address and it worked. I didn't use the Brother software with the last router so I assumed the same was true this time. Thank you very much.
michaelkenward wrote:Given the symptoms you describe, it might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
The modem is a Netgear CM600.
michaelkenward
Feb 08, 2021Guru - Experienced User
Smells like a printer/PC issue. But I am not familiar with Brother printers.
However, it make sense to me to at least trying to follow the maker's instructions before moving on to esoteric DNS tweaks.
temmet wrote:The modem is a Netgear CM600.
Nothing complicated to get in the way there.
- temmetFeb 21, 2021Aspirant
I apologize for the break between my posts. I'm back, with the same DNS problem. My printer issue has been resolved but I'm still getting strange DNS problems. If it isn't my modem, what should I be checking next?
- michaelkenwardFeb 22, 2021Guru - Experienced User
It remains unclear to me what these "strange DNS problems" are.
- temmetFeb 23, 2021Aspirant
Here is an example of what happens: I have a wired connection to my router. I attempted to connect to an IMDB webpage while I was simultaneously streaming Amazon music. The IMDB page didn't load, despite streaming music. I refreshed the Amazon page and it came right back. For about 20 seconds, Chrome gave me DNS error codes whenever I tried to load the page, except for a few times when it instead stated it lost internet connectivity. Windows didn't show a network disconnection.
While writing this message, I used Firefox. It alterted me several times it was disconnected from the internet and autosaved the draft but the music never stopped.The Steam application's internal web brwoser will also fail to load a page it was just displaying, or to a linked page. Across browsers, these aren't just slow load times - the attempts will time out and display a DNS error about not being able to find the host. The only browser which doesn't display a DNS error is Edge, but it will just hang and hang and hang and eventually load the page, but it approxmiately the same time as the others do.
Is that clearer? I assume they are DNS problems because the browers are displaying DNS error codes. Is there something else I should be checking?
