雪夜星辰
Nov 14, 2021Star
Do I need open OFDMA feature of RAX70 router
I found the OFDMA feture check box of wifi setting function for 2.4G and 5G band, but those are normally don't selected, what's the function of this feature, and what time or situation I should open it? Dose this feature will enhanced connect speed and stability?
雪夜星辰 wrote:
Wow, that's too complicated for a green hand user to understanding, I have open the OFDMA feature for my 5G channels, will see if will improve a little to reduce the delay.
the full article is a little complex. But it basically boils down to it might have some improvements but its not a game changer.
there's a ton of info on ofdma. so much so that this site did a 2 part feature on it.
https://www.smallnetbuilder.com/wireless/wireless-features/33222-does-ofdma-really-work-part-1
https://www.smallnetbuilder.com/wireless/wireless-features/33223-does-ofdma-really-work-part-2
I'd recommend at least reading the conclusion to the article.
- 雪夜星辰Star
